2011 Silverado Hd New Design
I'm sure this has been posted already, but I was just watching the Chicago Auto Show on tv and the Silverado looks pretty good with the new bumper and grill! What do you guys think?
http://www.chicagoautoshow.com/vehicles/de...;vehicle_id=907
I think GM made this change so the Silverado and Sierra can use the same bumpers = save money = getting smarter!
Only changes are the bumper and grill. Front end flows a little better now.
Imagine the entire front bumper, grill, bowtie and mirrors all body matched with some nice wheels and tires...now that would look SICK!
I like the look. Most of the 2011 updates are under the skin. The 2011 gets a fully boxed frame, for example, and things have been beefed up to increase the payload/tow ratings. Looks like some substantial changes to me.
This is one badass rig boys check it out.
GM is using the Chicago auto show to unwrap its latest salvo in the heavy-duty pickup wars: the 2011 Chevrolet Silverado Heavy Duty. Available in three-quarter- or one-ton strengths, the new Silverado HD is a workhorse aimed squarely at the new 2010 Dodge Ram Heavy Duty and 2011 Ford F-series Super Duty.
While it consists almost entirely of mechanical updates, rather than a complete vehicle overhaul, the new Silverado HD indeed appears to be a serious piece of work-site hardware. Although the company has yet to outline the improvements for the Silverado’s twin, the 2011 GMC Sierra Heavy Duty, the two should remain identical under the skin, with the GMC set apart by the usual unique aesthetic tweaks.
Harder Hardware and Smarter Software
While GM’s previous HD trucks were no wet noodles, the new Silverado’s underpinnings might as well be milled from solid billet by comparison. The basic formula stays the same—body-on-frame construction, a leaf-sprung live rear axle, and an independent front suspension supported by torsion bars—but every bracket, fastener, and crossmember has been substantially beefed up. GM says that the only significant components to be carried over from the 2010 chassis are the front end’s attachment links for the anti-roll bar.
The Silverado HD’s frame is all new and is now fully boxed for greater strength and rigidity. The truck is available in 11 different configurations, and the frame has been designed for easier mounting of a fifth-wheel hitch in the bed. The conventional rear-mounted hitch is more robust, too.
Maximum towing capacity is said to be a nice round 20,000 pounds with the fifth wheel—16K with the standard hitch—while payload capacity tops out at 6335 pounds. Ford has yet to release its ratings for the ’11 Super Duty, but the 2010 Dodge Ram HD is capable of carrying up to 5130 pounds in the bed and towing up to 17,600 pounds.
The rear suspension’s multi-stage leaf springs are wider, at a full three inches, and are of an asymmetrical design, both of which allow for greater load-carrying ability and improved axle control, according to GM. The independent front suspension—still unique to GM in this segment—has been completely redesigned and can now support up to 6000 pounds, and the minimum weight supported by any four-wheel-drive configuration is enough to allow a snow plow to be fitted. Despite the greater complexity of the GM trucks’ independent front suspension (upper and lower control arms made of forged steel and cast iron, respectively) versus its competitors’ solid-axle layouts, the company remains adamant that the setup offers the same capability while delivering a better ride and being easier to tune for specific applications. The company says the torsion bars can be adjusted with a wrench to compensate for the greater load that a snow plow would apply to the front end.
Along with larger disc brakes—14 inchers front and rear—a standard engine-exhaust-brake system, slightly wider front and rear tracks, and longer wheelbases ranging from 133.6 to 167.7 inches, several other electronic additions are new for 2011. Single-rear-wheel models come standard with electronic stability control, hill-start assist, and automatic grade braking, with a trailer-sway-control system as an option.
The Race to 700 lb-ft of Torque
While outputs have yet to be released, powertrains for the 2011 Silverado HD include a 6.0-liter OHV V-8 paired with a strengthened 6L90 six-speed automatic, as well as the turbocharged 6.6-liter Duramax V-8 diesel with an updated version of the Allison six-speed automatic.
The 6.0-liter**—rated for 360 hp and 380 lb-ft of torque in the 2010 model—gets variable valve timing and a new camshaft, among other tweaks, which GM says will offer a broader torque curve and better efficiency overall. However, the real news is the fourth-generation Duramax diesel, about 60 percent of which the company says is new for 2011. Along with new pistons, rods, and a revised exhaust-gas recirculation cooler, the new diesel is said to be both quieter than before and up to 11 percent more fuel efficient on the highway. Oxides of nitrogen emissions are down 63 percent, too. The common-rail, piezo-actuated fuel-injection system now operates at 30,000 psi and can run on B20 biodiesel.
The exhaust-treatment system has been optimized for 5000-mile service intervals between 5.3-gallon fill ups of fluid for the selective-catalytic-reduction system, while the diesel particulate filter can now go up to 700 miles (up from 400 miles) between regenerations, which helps reduce fuel consumption. Total range for the diesel is now up to 680 miles with the Silverado HD’s standard 36-gallon fuel tank.
GM says specific output for the Duramax is pending SAE certification. The third-gen Duramax made 360 hp and 660 lb-ft of torque—tops in its class—yet GM officials are optimistic that more than 400 hp and 700 lb-ft are in reach with the 2011 modifications. We expect details to come soon, along with specs for Ford’s new 6.7-liter PowerStroke V-8 diesel, which also has been rumored to be close to the 400-hp and 700-lb-ft marks.
The Shiny Stuff
Recognizing the 2011 Silverado HD will pretty much be possible only from the front, as the only changes to the body are a new raised hood with revised Duramax/Allison badges, as well as a new chrome front bumper. New 17- and 18-inch wheels are available across the range, while polished and forged 20s are available on 2500HD models.
The interior is largely carried over, which is fine; the 2010 trucks were well-appointed and very comfortable. The latest version of OnStar is available, as is mobile WiFi, USB, and Bluetooth connectivity. Touch-screen navigation, XM satellite radio, and a rearview camera remain optional, as do other luxury amenities. A slight increase in base prices is expected, but GM says it’s too soon to say how large of a premium the new capabilities will command.
More significant updates to the exterior and interior likely won’t come for another couple years, as GM only recently restarted development of the next-generation, light-duty Silverado and GMC Sierra, which are expected in 2013 or so. Fortunately, that gives us plenty of time to line up the new Silverado HD against the latest Ford and Dodge trucks for another heavy-haulin’ comparison test. Load ’em up
    250.3k
    Mgyselinckjr
    Mgyselinckjr
  • Who's Online   3 Members, 0 Anonymous, 326 Guests (See full list)
